Overview: You can use the Get Image Invoke Node to save an image of your graph on a JPEG file and Report Generation Toolkit VIs to open your document and append the image to it.
Description:
You can use the Get Image Invoke Node to save an image of your graph on a JPEG file.
Also, you can use the VIs from LabVIEW Report Generation Toolkit to open your document and append the image to it.
Requirements: LabVIEW 2012 (or compatible), Report Generation Toolkit. MS Office. Hardware: none.
Steps to Implement or Execute Code:
1. Write down the full path to your jpg.
2. Run the VI.
3. Save doc document where you want.
4. Open doc to check.
Additional Information or References:
If you would like to use snippet - Click on Browse... button when LabVIEW will start searching for the subVI and select the subVI from the folder where you unzipped the archive.
Thanks for this. Works great. Have you made a VI that will insert it wherever you want in the word document rather than appending it to the end?
Thanks again!
Thanks for your share .
I will try it
