How to Update Firmware on the NI USB-6008/6009 for Use with the DAQmx Base Driver 3.X or Later
Introduction
This video tutorial demonstrates the process by which users may update the firmware on the USB-6008/6009 for use with the DAQmx Base driver. This process requires the windows platform. Please see Knowledgebase 491FPHB9, for additional information.
Note:
This tutorial is best viewed in 720 HD, with Fullscreen enabled. You may Right-Click, and view the information directly at the YouTube host site, where resolution settings may be adjusted.
Patrick Corcoran
Application Engineering Specialist | Control
Il codice di esempio scaricato dall'Example Code Exchange nella NI Community è concesso in licenza con la licenza MIT.
Commenti
k.gr
Member
Member
su
I am wondering where to find FWUpdate in LabVIEW 2015 ?
