Description
Description-Separate-1This Demo demonstrates how to acquire signals using the PXIe-5764 digitizer and perform signal analysis on FPGAs, such as FFT transformations. The demo system is composed of PXIe-5764 digitizer, PXIe-1095 chassis and PXIe-8881 controller, which can simultaneously collect data from 4 analog channels at 1GS/s sampling rate, with analog trigger, digital trigger, custom software trigger and other trigger functions, and the single-channel trigger frequency can reach 1MHz.
Description-Separate-2How to Use
How-Separate-1
- Download and unzip the attached ZIP-file
- Open PXIe_5764_Demo LabVIEW project and build the 5764_FPGA_FFT_DEMO.vi
- Open the [Host] PXIe-5764 Demo Host.VI inside the LabVIEW project and follow the instructions on the Front Panel
How-Separate-2Additional Information
Additional-Separate-1
Additional-Separate-2
