Description
Description-Separate-1Overview
This VB script will create a new waveform channel from a section of another channel while keeping the time data intact.
Description
The VB script follows this KnowlegeBase article. This example is a workaround because DIAdem does not save the time data when you make a new channel from a section of waveform data. The next edition will include using the cursors or flags to identify what section of the Waveform channel to duplicate.
Requirements
- Open in DIAdem SCRIPT
- Change constants as needed
- Load channel you with to take a section of
- Set Active Channel Group in Data Portal
- Run script
- See new channel that is generated by the script
Description-Separate-2
