Example Code
Enumerate IMAQ Interfaces (Cameras)
Products and Environment
    Software
  • LabVIEW
    Driver
  • NI Vision Acquisition Software
  • Other
Code and Documents
Overview
The example demonstrates how to list connected NI-IMAQ and NI-IMAQdx cameras.
Description
The example allows you to enumerate any IMAQ or IMAQdx interface (camera) using the NI System Configuration API.
Requirements
 Software
  • LabVIEW 2012 Base Development System (or compatible)
  • NI System Configuration API 14.0 (or compatible)
  • NI-IMAQ 14.0 / NI-IMAQdx 14.0 (or compatible)
 Hardware
  • Any camera that can be used with either the NI-IMAQ or the NI-IMAQdx driver (for further information see linked Knowledgebase article)
  1. Open the attached file
  2. Run the VI
Knowledgebase: What Is the Difference Between NI-IMAQ, NI-IMAQdx, and NI-IMAQ I/O?
http://digital.ni.com/public.nsf/allkb/0564022DAFF513D2862579490057D42E
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
Vince M
Applications Engineer
Comments
marygreen
on
how can I get the other functions related to cameras (like , open , close camera, get image, start, configure aqcuisition , grab )
Maryam zeinalzadeh
Not applicable
on
Those functions install with the Vision Acquisition Software and show up in the Vision and Motion palette in LabVIEW. If you want, they are all in a simple location using the community example that I posted:
Image Acquisition Functional Global Variable (IMAQ or IMAQdx)
But this example does require that software.
seVEMes
marygreen
on
HI.
THanks for the reply,
I have installed all IMAQ and IMAQdx . but still when I run the VI file.. I receive errors ,,, that these functions have not been found or these sub vi's are not executable ( i.e. open camera .vi,.. close camera.vi , etc... )
marygreen
on
HI.
Please find the atached file which shows all the errors I receive.
M:Z
BranchSupport-NIC
commented on the document
"Enumerate IMAQ Interfaces (Cameras)"
To view all comments on this document, visit:
http://decibel.ni.com/content/docs/DOC-14712#comment-14682
seVEMes
on
Please contact National Instruments for support questions and ask to talk to the vision support group if you cannot find the resolution to your problem on the forums or through help or support documents (ni.com/support).
Vince M
zou
Trusted Enthusiast
Trusted Enthusiast
on
I found this function does the same:
imgInterfaceQueryNames
http://zone.ni.com/reference/en-XX/help/370161G-01/imaqfr/imginterfacequerynames/
George Zou
