Example Code
Differential M-PSK Demodulator
Code and Documents
Overview
This example demodulates a continuous differential M-PSK modulated signal.
Description
This example demodulates a continuous differential M-PSK modulated signal, and tracks timing and frequency offset. In addition, if the transmitted bit sequence is a Galois PN sequence, then bit error rate can be measured.
  1. Unzip and open the project.
  2. Deploy the FPGA bitfile to your PXIe-5641R.
  3. Open host VI and customize Rx configuration.
  4. Run host VI.
Requirements
Software
LabVIEW FPGA 2010
LabVIEW FPGA RF Communications Library 3.0 available on NI Labs
Hardware
PXIe-5641R
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
Comments
Member
Member
on
This is a very good example to understanding the DBPSK algorithm.
Member
Member
on
there is no zip file in this ......
plese help me any one where i can find it example code for dbpsk
Member
Member
on
I am using PXIe-5641R to make a DPSK modulator. Is there am example to do this?
Member
Member
on
Member
Member
on
Hello every one,
             i am using this example  LV2010 5641R DPSK demodulator .when i compile this on NI PXie 5641R i get the following error shown above.it keeps on compiling for about 38 minutes mentioning generating cores.then this error appears.so any one knowing about this error.
My system RAM is 4 GB .
thankyou.
NI Employee
on
Hi jadoon,
Please try applying this hotfix - http://joule.ni.com/nidu/cds/view/p/id/3864.  If that doesn't work, I would advise you to call support at (866) ASK-MYNI or post in our forums.  Our systems don't streamline the ability to support you through the comments section of these documents.
Good luck!
Chris Elliott
x36772
Member
Member
on
Hi chris,
                 thankyou for reply. i am using Labview 2011 SP1.the patch you mention is for 2012 SP1 .so any solution possible for that..
thankyou .
Member
Member
on
please convert
LV2010 5641R DPSK Demodulator.zip
to labview 2009 with me
thancks my dear
Contributors
