Overview
For many strain gage tasks, a sampling rate lower than the valid NI-9237 sampling rates is necessary. The NI-9237 can only accepts specific sampling rates which can be found in the User Manual, or in this KnowledgeBase article link: What Are the Valid Sampling Rates for the NI 9233, NI 9234, and NI 9237? This example below can be used as a method to decrease the effective sampling rate of the NI-9237 to 100Hz.
Description
There are several methods to decimate the signal of the NI-9237, but this example uses finite acuqisition and takes the first of every 20 samples in a waveform using the Decimate 1D array function. The data is then displayed in an array and waveform graph. This example is configured to work with the valid sampling rate of 2kHz and 400 samples per channel. Because it only takes the first sample of every 20, the code outputs an array of 20 samples at the end of the acquisition. Additionally, it effectively samples at ~100Hz. This code will work for multiple channels on your device.
Requirements
Software
Hardware
Additional Information and References
