Example Code
Convert Thermocouple Voltage to Temp
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI will demonstrates how to mathematically calculate the acquired voltage to temperature reading using thermocouple
Description:
This VI is designed to convert raw voltages into temperatures for a wide variety of thermocouple types. You can use this function to convert voltage for types that are not supported in DAQmx. Just create a voltage task input and use this VI to convert to a temperature.
Steps to implement or execute code
To implement this example:
  1. Fill all the input of the front panel
  2. Run the VI
  3. (Optional) Turn on the Highlight Execution to see the flow of the VI
To execute this example:
  1. Install the required software.
  2. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
Comments
khalsans
Member
Member
on
Great work, but you will also need the reverse polynomials if you plan on doing CJC .
The is a vi for reading the CJC temp:
DAQmx Acquire CJC Temperature
https://decibel.ni.com/content/docs/DOC-11132
And I did find reverse polynomials (T to V) at Omega's site.
