Example Code
Controlling DTR RTS Lines On A Serial Port
Products and Environment
    Hardware
  • Other
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates manually changing states of the DTR and RTS lines on a serial port.
Description
Property nodes are used to set the states of the DTR and RTS lines. An event structure is used to detect changes to two buttons that correspond to the DTR and RTS lines.
  • Configure the Serial Port (optional). Make sure Flow Control is set to None.
  • Create an event structure to detect change of value for the DTR and RTS buttons
  • In the DTR Value Change state, create a property node with the VISA serial resource name. Click on the property node and select Serial Settings » Modem Line Settings » Line DTR State.
  • In the RTS Value Change state, create a property node with the VISA serial resource name. Click on the property node and select Serial Settings » Modem Line Settings » Line RTS State.
  • Close the VISA session
Requirements
Software:
  • LabVIEW 2012 (or compatible)
Hardware:
  • Device with serial interface
  1. Open the VI "DTR_ RTS Serial Control_LV2012_NI Verified"
  2. Choose the VISA Resource Name
  3. Run the VI
  4. Click to modify DTR and RTS status
  5. Stop Execution
Peter Flores
Comments
cacalderon
Member
Member
on
Thank you!!!!
Very useful feature of the serial port.
____________________________________________
Carlos Calderón Córdova, Ing.
Universidad Técnica Particular de Loja
Grupo de Control, Automatización y Robótica
Escuela de Electrónica y Telecomunicaciones
Phone: (+593) 7-2570275 ext. 2650
Cell: 098663798
e.g.lll
Member
Member
on
Thank you!!!!
