Example Code
Change Properties of All Controls and Indicators in a Cluster with LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how to access the properties of the controls and indicators in a cluster.
Description
Create a property node from the cluster by right-clicking the Cluster on the Block Diagram and select Create»Property Node»Controls [].  This gives you an array of references to the Controls.  You can then cast them to the specific class of control and access the properties from the reference.
Requirements
  • LabVIEW 2012 SP1 (or compatible)
Steps to implement
  • Download and unzip "Plotting geometric shapes in LabVIEW - LV2012 NIVerified.zip" and and save the content in the same folder.
  • Run the .vi
Change Properties of All Controls and Indicators in a Cluster with LabVIEW - LV2012 NIVerified.PNG
Bryan H.
