Overview
This document has been archived and is no longer updated by National Instruments.
This example demonstrates the procedure required to apply different NI-DAQmx custom scales to each virtual channel in a task. First, you used a DAQmx task Property Node (Functions>>NI Measurements>>DAQmx - Data Acquisition>> DAQmx Advanced Task Options) to obtain the task's virtual channels. You then use a DAQmx channel Property Node (Functions>>NI Measurements>>DAQmx - Data Acquisition) to set the custom scale for each virtual channel in the task.
