Overview
A new version of the example and a new VI to add to the previous library to show how Agilent E4980 works with frequency sweep.
Description
It is saved along with the regular Fetch Measurement Data. It should be in instr.lib\Agilent E4980\Public\Data\Low Level assuming you placed the library in the intr.lib. This VI does an actual sweep in the LCR meter.
Requirement
The sweep VI included in the driver on NI's website does not work. There are a couple of issues with it.
UPDATE (6/10/2015): Updated the code, as I had originally left the default 512 character request for the fetch, which is not big enough for large sweeps. I changed the code to allow the value to be specified, and changed the default to 4096.
UPDATE (6/7/2016): Added LV8 version of the VIs. Rename them to drop the "80" at the end of the VI name.
UPDATE (9/27/2016): Someone noticed that the Fetch for LV8 was still in LV14. It has been updated.
First,I sorry for my langauge,I'm a native.
I'm student and I'm a beginner in labview.I want to display list sweep 201 value on lcr meter is controled via My PC and I also download instrument driver form labview.When i'm connected lcr meter with my notebook,it can runs only three point(1000,2000,5000) which it's not my expect.I don't know how to setup your attached and how to add a new VI to the library when I'm double click Agilent E4980 Read Measurement List Sweep.viit tell me some file has been deleted (I guess Fetch Measurement Data (List).vi) Could you tell me in details please?
Thank you so much
Agilent E4980 Read Measurement List Sweep.vi is an example to show you how to properly do a sweep on the LCR meter. It has default values that are 1000, 2000, and 5000. You need to change these values to sweep a different set of frequencies.
Copy the Fetch Measurement Data (List).vi to Public\Data\Low Level directory of where the Agilent library is. This may be, for example, C:\Program Files (x86)\National Instruments\LabVIEW 2014\instr.lib\Agilent E4980\Public\Data\Low Level, but depends on your version of LabVIEW, and assuming you put the Agilent library in the instr.lib folder.
Copy the Agilent E4980 Read Measurement List Sweep.vi to the Examples directory of where the Agilent library is. This may be, for example, C:\Program Files (x86)\National Instruments\LabVIEW 2014\instr.lib\Agilent E4980\Examples.
To add the files to the library and project, open the Agilent E4980.lvproj, which is in the root of the library install (again, for example, C:\Program Files (x86)\National Instruments\LabVIEW 2014\instr.lib\Agilent E4980).
Once the project is open, you should see an Examples folder. Right-click on it and choose Add->File... Then select the Agilent E4980 Read Measurement List Sweep.vi file. Now, the example should be in the project.
Back in the project, you should also see Agilent E4980.lvlib. Expand it so you can see Agilent E4980.lvlib\Public\Data\Low Level. Right-click on the folder, and choose Add->File... and choose Fetch Measurement Data (List).vi.
Save everything, and the example should not complain about any missing code.
I have Labview 2012 so I could not read your VI fields. If it is possible, can you please send me the 2012 version.
Thanks you so much.
I added LV 80 versions of the code. Rename them and drop the "80" from the end of the VI name before using them.
Thannks for your help. Your program is amazing ! It does works very well.
Quyen
Hi dear Matthew_Kelton
Do you have any suggestion for my problem:
Frequency sweep from F1 (for eg100 Hz) to Fn (for eg1000Hz) with specific steps for eg 100Hz, and obtain 2 different output (such as Cp and Rp) for each frequency, using Agilent E4980 driver vi's.
another question: In Read Measurement list sweep code what is the high and low band limit? If frequency sweeps are our inputs what are outputs? how can we define them? How can obtain for eg Rp and Cp?
Thank you in advance
Dear Matthew_Kelton
I have a problem. The primary and secondary values in the "sweep list VI" are frequently reset to zero (about few seconds, not periodically).
Do you have the same problem ? if yes, do you have any idea how to fix it ?
Thanks you in advance.
If you look at the example, the Configure List Sweep VI has two unwired inputs, Sweep Function A and Sweep Function B. Have you tried playing with those? I don't have the hardware anymore, so I cannot do any testing. If that doesn't work, you may have to do the sweep twice, configuring for each measurement.
Are you running that as a subVI? The unit I believe reports 0 when it cannot do the measurement. I have code that shows if I get a value less than 1, I changed it to NaN to show the unit couldn't perform the measurement.
Thank you for your reply.
What are high and low band limits?
Dear Matthew_Kelton,
I found the problem ! It is due to the external trigger. When I set Bus triger, it works .
I set the Sweep Function B as None and Sweep Function A as Frequency. I do not well understand what is the difference between the two functions. I appreciate if you could clarify to me.
Hi Matthew,
The Fetch Measurement data (List)80 is still in LV14 version. Would you be able to upload the LV8 version please. This would be much appreciated.
Many thanks.
Sorry about that. It should be fixed now.
Great! Many thanks for your swift help Matthew.
Hi Matthew,
I was able to do 12 sweep measurements. However, when I increased the number further,
I received an error message: Error -1074000000 occurred at Agilent E4980.lvlib:Error Query.vi, with possible reason(s): Instrument reports: -420,"Query UNTERMINATED" +0,"No error". Complete call chain: Agilent E4980.lvlib:Error Query.vi; Fetch Measurement Data (List).vi; Agilent E4980 Read Measurement List Sweep.vi.
The error occurred although the instrument was able to finish the whole sweep measurements (i have tried up to 50 sweeps).
The error-in code I got at Fetch Measurement Data (List) VI is -1073807339 whereas the error out code is -1074000000.
I have tried to increase the buffer size, but this did not solve the problem as perhaps the error occurred before that VI. Would you be able to shed some lights please?
Many thanks for your help.
The -1073807339 erorr is a timeout error. You need to modify the Initialize VI to increase the timeout from the 10000 ms it is currently set to.
Hi Matthew,
Great thanks! You have saved me from many hours of frustation . . .
Thank you once again
Hi Matthew,
How can you change the primary and secondary parameters from Cp and D to Z and Theta?
Nate
Hi Matthew,
Nate
Nate,
Wire inputs to the Configure List Sweep subVI. Sweep Functions A and B.
Matthew
