Overview
Expanded version of E363X example - allows the user to set and read multiple outputs.
Description
This is a expanded version of the E363X version VI that is already available on this site. It has been expanded to three channels and tailored specifically for that supply. To prevent the initialization routine from turning off the power while running continuously, I have place it outside the main while loop. Meaning you should not try to change the GPIB address after starting the VI. If you have comments / suggestions I will try to implement them
Requirements
Software
LabVIEW 2012(or compatible)
NI-VISA
Hardware
GPIB adapter
Agilent E3631A supply
about vi
i am a graduate student,and i am looking a vi file to control my E3631A power supply,but my labview could not open your vi file,in that different labview version,is there any solution you can offer,thanks
