Enhanced Icon Editor
Reply
Highlighted
Manual User Input bug?
Hallo to everybody... I am new in this group.
Since I had some problems in Sincronizing with ni.com Icon Library the program proposed me the option of sincronizing manually.
After having set the .zip and the .xml paths I found that the OK button in Manual User Input do... nothing.
I had a look at the code and I found that the event case for "OK" always set FALSE the EXIT for TRUE node of the main while loop.
So I modified the diagram adding an OR function...
It seems to me, if I am not wrong, that this can solve the problem...
Thanks to all for the great Enhanced Icon Editor... and sorry for my poor English!!
Cheers.
Marco.
(1,402 Views)
Re: Manual User Input bug?
Hi Marco,
really good catch!
I guess that you are using a proxy server, therefore the HTTP request doesn't go through.
I am kinda embarrassed that I didn't see this problem when I run some basic tests on this dialog.
I have created CAR 182828.
Tom
http://www.newgistics.com
(861 Views)
Hi Tom,
you have no reason to be embarassed .
I know very well how difficult is to test every branch of a program, out of the "main stream"...
I got the problem because I hit it by accident almost immediatly. One of the first thing I tested in LW2009 is the new Icon editor.
At work I have access to the internet through a firewall, as you supposed, so my request of sincronizing were refused.
Trying to investigate the error I discovered, first of all, that the code for the new Icon Editor is "open source".
This is really GREAT!!! Thanks to NI...
You know the rest of the story...
Cheers.
Marco.
(861 Views)
Reply
