Embedded Systems Conference
Reply
Highlighted
NI Products to be featured at ESC 2010
Hardware
Single Board RIO
NI Single-Board RIO products are low-cost embedded deployment solutions based on NI CompactRIO. They integrate a real-time processor, reconfigurable field-programmable gate array (FPGA), and analog and digital I/O on a single board and are powered by NI LabVIEW Real-Time and LabVIEW FPGA technologies. The built-in analog and digital I/O can be expanded using C Series modules.
Board-only C Series
With the new embedded C Series modules, engineers and scientists easily can add measurement quality I/O to their applications by plugging any combination of the new modules directly into the three I/O expansion ports on NI Single-Board RIO devices. The 15 modules include a three-channel, 300 V analog input, 16-channel analog output module; four-channel, 24-bit bridge/strain module; and four-channel, 24-bit universal module.
Compact RIO
The National Instruments CompactRIO programmable automation controller (PAC) is a low-cost reconfigurable control and acquisition system designed for applications that require high performance and reliability. The system combines an open embedded architecture with small size, extreme ruggedness, and hot-swappable industrial I/O modules. NI CompactRIO is powered by reconfigurable I/O (RIO) FPGA technology.
Smart Camera
National Instruments Smart Cameras are industrial, high-quality image sensors combined with powerful processors to create rugged, all-in-one solutions for machine vision applications. You can use these cameras for applications including quality control, packaging verification, robot guidance, optical character recognition, and 2D code reading. NI Smart Cameras integrate easily with Programmable Automation Controllers (PACs), PLCs, and industrial HMIs. NI Smart Cameras are shipped with the NI Vision Builder for Automated Inspection (AI), configurable machine vision software that requires no programming.
ARM Evaulation Boards
The LabVIEW Embedded Module for ARM Microcontrollers provides a selection of evaluation hardware boards that allow developers to prototype their ARM application before moving to custom ARM hardware. This document will detail board features, processor specifications and links to find more information from the manufacturer.
FlexRIO
NI FlexRIO hardware provides flexible, customizable I/O for NI LabVIEW FPGA. It features two parts: NI FlexRIO field-programmable gate array (FPGA) modules for PXI and NI FlexRIO adapter modules. Together, they form a high-performance, reconfigurable instrument programmable with LabVIEW FPGA software.
Software
For more than 20 years, NI LabVIEW graphical programming has revolutionized the development of test, measurement, and control applications. Regardless of experience, engineers and scientists can rapidly and cost-effectively interface with measurement and control hardware, analyze data, share results, and distribute systems.
LabVIEW FPGA
The NI LabVIEW FPGA Module uses LabVIEW embedded technology to extend LabVIEW graphical development and target field-programmable gate arrays (FPGAs) on NI reconfigurable I/O (RIO) hardware. LabVIEW is distinctly suited for FPGA programming because it clearly represents parallelism and data flow. With the LabVIEW FPGA Module, you can create custom measurement and control hardware without low-level hardware description languages or board-level design. You can use this custom hardware for unique timing and triggering routines, ultrahigh-speed control, interfacing to digital protocols, digital signal processing (DSP), and many other applications requiring high-speed hardware reliability and tight determinism.
LabVIEW Real Time
National Instruments real-time products combine the NI LabVIEW graphical development environment with LabVIEW Embedded technology to achieve the deterministic performance of dedicated real-time and FPGA targets. Deliver applications that run predictably in time with increased reliability and offer stand-alone operation.
LabVIEW for ARM Microcontrollers
The NI LabVIEW Embedded Module for ARM Microcontrollers delivers graphical programming to the popular embedded 32-bit reduced instruction set computing (RISC) processor. This module provides a comprehensive development environment for ARM7, ARM9, and Cortex-M3 microcontrollers. Order your low-cost evaluation kit to discover how graphical programming can help you develop higher-quality code more quickly.
Other Important Resources
From Rapid Prototyping to Low-Cost Deployment, Get to Market Faster with these NI Products
NI Advantages for Embedded Design Resource Kit
Introduction to ARM Microcontrollers
Programming ARM Microcontrollers with LabVIEW
Message 1 of 1
(6,542 Views)
Reply
