11-05-2007 11:18 AM
I have a PCI-4462 that I need to get 196K samples per second on each of the 4 channels.
I have vista 64 on a 4 core 3 GHz board.
Signal express can only give me a 60% measurement duty cycle on this system while logging to disk, I need 100%. I do not have the CPU cycles/ disk speed to run a bunch of extra software. I believe I do have a system that will do the job it the software is efficient.
I do not see the need for measurement studio. I just want to run Visual basic 2005 EXPRESS with as little overhead as I can get.
My problems are:
1) The examples shipping with DAQmx will not run my board. If the example shows commands that the board does not support is it really an example or just a bunch of noise to weed through? They use DAQmx API commands the 4462 does not support.
2) I have not been able to find a set of VB text based commands to configure board and acquire data. I have not been able to find a list of any commands the board can support. I know it does change gain and does read data. Signal Express knows how to talk to it nicely so it will behave. The documentation I have found assumes measurement studio is installed and the 4462 will support all the AI related DAQmx commands.
3) I have not found any documents on the 4462 API.
I have been working on this for months now and the frustration level is rising. Is there someone who can point me in the correct direction?
My configuration:
Hardware ASUS L1N64-SKI WS mother board.
2 AMD FX 74 CPU
OS Name Microsoft® Windows Vista™ Ultimate
Version 6.0.6000 Build 6000
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name JOHN-PC
System Manufacturer ASUSTek Computer INC.
System Model L1N64-SLI WS
System Type x64-based PC
Processor AMD Athlon(tm) 64 FX-74 Processor, 3000 Mhz, 2 Core(s), 2
Logical
Processor(s)
Logical
Processor(s)
BIOS Version/Date American Megatrends Inc. 0301, 3/13/2007
SMBIOS Version 2.4
Windows Directory D:\Windows
System Directory D:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "6.0.6000.16386"
User Name john-PC\john
Time Zone Pacific Daylight Time
Total Physical Memory 4,094.63 MB
Available Physical Memory 2.81 GB
Total Virtual Memory 8.15 GB
Available Virtual Memory 7.05 GB
Page File Space 4.29 GB
Page File D:\pagefile.sys
Visual Basic 2005
version 8.0.50727.867 (vsvista.050727-8600)
11-06-2007 08:59 AM
11-06-2007 11:07 AM
Hello Gavin,
"I just want to run Visual
basic 2005 EXPRESS with as little overhead as I can get."
Sure,
why not
It
just seems that almost everything I read assumes that I am running
more NI software.
1) The 4462 uses the same DAQmx API that
other NI DAQmx products use, that's the beauty of our driver.
Which example is not working for you? A "for sure"
that I can run on my machine is the example with "Acq-Int-Clk"
in the name. The C version of this example on my machine is
located here C:\Program Files\National
Instruments\NI-DAQ\Examples\DAQmx ANSI C\Analog In\Measure
Voltage\Acq-Int Clk.
John: Elizabeth found 2 examples that would
run on my system.
There are a lot of commands DAQmx that a
4462 cannot do. An example it does not do AO or any digital and I
would not expect it to. Besides these there are commands that
are not as obvious.
I would like to know all the commands it
does support so I do not limit my self artificially. When I was
doing software development we had a saying if it is not
documented it does not exist.
2) The function
calls/parameter lists, I believe, are the same as our C API, so you
can use either those examples or the Measurement Studio examples to
help jump start your program.
Are you telling me the
"Measurement Studio examples" do not use any Measurement
Studio code?
3) All DAQmx devices follow the same API
John:
the problem is the API is very large and about 3/4 of it does not
work in my setup.
Measurement Studio help has a much bigger index
than real pages. It looks like all the Measurement Studio index is
there but the Measurement Studio only pages are not. I spend a lot of
time fallowing ling to pages I do not have. Feels like the lawyer who
ask for a letter and the other lawyer sent the letter along with
100,000 other letters in an 18 wheel truck.
Here is a MAX 4462 configuration.
I am trying to do this configuration in VB
DAQmx] MajorVersion MinorVersion
8 6
[DAQmxChannel] AI.Coupling AI.Max AI.MeasType AI.Min AI.TermCfg I.Voltage.Units ChanType PhysicalChanName
PPI2/PrimaryVolts DC 42 Voltage -42 Differential Volts Analog Input Dev1/ai0
PPI2/PrimaryCurrent DC 1 Voltage -1 Differential Volts Analog Input Dev1/ai1
PPI2/SecondaryVolts DC 42 Voltage -42 Differential Volts Analog Input Dev1/ai2
PPI2/SecondaryCurrent DC 1 Voltage -1 Differential Volts Analog Input Dev1/ai3
[DAQmxTask] Channels SampClk.ActiveEdge SampClk.Rate SampClk.Src SampQuant.SampMode SampQuant.SampPerChan SampTimingType
Rising 195000 Continuous Samples 2000 "" Sample Clock
PPI2 PPI2/PrimaryVolts, PPI2/PrimaryCurrent, PPI2/SecondaryVolts, PPI2/SecondaryCurrent
[DAQmxDevice] BusType DevSerialNum PCI.BusNum PCI.DevNum ProductNum ProductType
Dev1 PCI 0x127B518 0x5 0x6 0x7170 PCI-4462
Thank You very much for the input.
11-06-2007 02:57 PM
11-06-2007 05:49 PM
