Dynamic Signal Acquisition
Using NI USB 6009, can i get all readings from a load cell measuring at 100Hz?
I would like to know whether a load cell, taking readings on a specimen which is fatigue loaded at 100Hz, can be connected to NI USB 6009 along with a computer to get the real time readings? The loading will continue upto 10-15minutes. The signals from the load cell has to be converted to force measurments  and has to be plotted later. Will a sampling rate of 1000 samples/sec be possible?
(5,844 Views)
tripple post
Greetings from Germany
Henrik
LV since v3.1
(5,828 Views)
