Dynamic Signal Acquisition
Specify a position and offset
I have received this message.
Possible reason(s):
Measurements: Attempted to write a sample beyond the final sample generated. The generation has stopped, therefore the sample specified by the combination of position and offset will never be available.
Specify a position and offset which selects a sample up to, but not beyond, the final sample generated. The final sample generated can be determined by querying the total samples generated after a generation has stopped.
Attempted to Write Sample: 8000
Property: RelativeTo
Corresponding Value: Current Write Position
Property: Offset
How I fix this error??
(6,620 Views)
Accepted by topic author renegia
It would be a lot easier to help if you could post your code...you probably just need to change a setting or two (finite/continuous, regeneration/non-regeneration, etc).
alan
(6,616 Views)
