Dynamic Signal Acquisition
Saving audio signal to a file
Hi everyone!
I was wondering if somebody could help with this one. I have got audio signal from four sensors that I want to save at the of a while loop, I tried using build array vi then to write to spreadsheet vi, but whenever I opened the file I could only see two rows one column of the data. And I expected to see four columns of numerous rows. Please advice on such a problem. Thanks.
(4,371 Views)
To start, I would recommend using the "write to measurement file" express VI.
http://digital.ni.com/public.nsf/allkb/CB46BC11A488621E86256D19005A386E
Save your file as a TDMS and use scout viewer to view your files after the fact
http://signalxtech.com/products/scout/
You can also use the express vi "read measurement file" to open it in LV.
(3,903 Views)
