Dynamic Signal Acquisition
Phase sign switch in measurement
Hello all,
I am performing a dynamic test using a piezo actuator PI 843.60 with a built-in displacement sensor in close loop and a force sensor from PCB 208C02. The modules I am using are NI 9269 to send a sinusoidal signal and NI 9215 to receive the data. I was wondering if anyone has ever have problem in which the phase between the input signal to the actuator and the displacement signal back from the sensor switches sign at a certain frequency. I analyzed the data with fft in Matlab and it doesn't seem like we have any resonance. I attach the graph I am getting.
Thank you for the help.
(4,196 Views)
Accepted by topic author DavidMu
Try unwrapping phase.
You can use this VI found in the LabVIEW palettes:
Doug
NI Sound and Vibration
(4,184 Views)
Thank you!
(4,169 Views)
