Dynamic Signal Acquisition
Major Modifications to existing LabVIEW and DAQ product pair
To All,
I am being forced to make major modifications to an application I built that has been in use since 2005.  Through that time period, I have had to change from Windows XP to Windows 7, which required an upgrade from LabVIEW 7 to LabVIEW 2015.  Now, I need to upgrade the PCI 6221 to the PCIe 6320 (Don't need Analog outputs) as well as Windows 10 upgrade.  I have already checked out my code with Signal generator vi's.  The end user has an SCC2345 with 6 ACC001 MODULES.  My plan is to have our IT guy install the new PCIe card and run DAQmx to make sure it talks to the PC.  Then load my code to make sure it at least 'wakes up'.  Then send the pc back to the end user that has the SCC2345 front end for final check.
Any issues?
Message 1 of 1
(3,161 Views)
