03-30-2017 03:07 AM
How to connect PCB 352C34 peizo acclerometer to NI9219 module of NI Crio 9082?
the cable consist one earth shielding and one input point,
03-31-2017 07:42 AM
The sensor is a ICP resp. IEPE type. You need a constant supply current in a range of 2mA to 8(?)mA. You DAQ doesn't directly support this type of sensor.
You need a IEPE capable DAQ or you build or buy a IEPE supply (J-FET plus resistor and a 24V supply) with decoupling (470µF /36V Capacitor)
03-31-2017 10:12 AM
Devices such as NI 9234, NI 9218, NI 9250, ... support direct connectivity to IEPE sensors.
