02-20-2026 09:36 AM
I keep getting a message saying ME Scope to a National Instrument cDAQ-9171 with a NI9234 voltage card installed. I have been able to make the front end successfully in the past. Can anyone tell me what I need to do to get the front end connection?
02-20-2026 10:09 AM
What has changed on this system since the last successful connection?
Which DAQmx driver version was installed by ME Scope? What other NI software is installed? If NI MAX is installed, are you able to see the 9234 and acquire data with a Test Panel?
If you already have LabVIEW Runtime 2024 or later and DAQmx driver with configuration packages installed, you can download the free DSA Soft Front Panels to use your 9234 which would verify the hardware is in working order.
What did Vibrant Technologies support team suggest?
