Hello Sannaa,
Thank you for your reply. So, you said that I don't have to divide my acquisition result by two. But is it because the division is done by the DAQ, or is it because the signal result of a sensor is ‘(positive signal – negative signal)’ and not ‘(positive signal – negative signal)/2?
Also, for the NI PXI4472B, I said that I had connected the positive signal and the negative signal of one sensor to one (of the eight) channel of the DAQ to be differential (pseudo) But I don’t know if that solution was good because the documentation say that we can't make a non-ground connection to the shield.
So the other possibility was to use 2 channels, one for the positive signal with its ground and the other one for the negative signal with its ground (see the outline in the attached file). Here, I do the subtraction between the two channels by my own thanks to a software (‘Matlab’). So, I don’t know if the positive signal is divided by two (and the same thing for the negative signal), or if I have to do it by my own thanks to a software (in the case that the signal result of a sensor is ‘(positive signal – negative signal)/2)
Thanks a lot,
ben
Message Edited by benbol on 05-24-2005 07:01 AM
