Hi Manasa,
You are pretty close, but you need to make one minor change. There is no need to use the Build Array function after the AI Single Scan VI. By using the Build Array function you are taking a one dimensional array and making it a two dimensional array. Every row in the 2D array besides the first one is empty.
Just remove the build array and connect the Scaled Data output of the AI Single Scan VI to the Array input of the Index Array and you should be able to see the rest of your graphs updating.
Best Regards
Hani R.
