Marni,
It is of great interest to me to be able to correlate a PCI bus and PCI device number to the device numbers (Traditional NI-DAQ) that MAX assigns to the PCI NI-4472s. My goal is to be able to designate a particular slot in the PCI bus as the location of the PCI NI-4472 "master" in a multi PCI NI-4472 synchronous configuration, and do it programmatically. To accomplish this, I need to be able to determine the NI-DAQ device number for the PCI NI-4472 that is in the "master" PCI slot. Once I know the NI-DAQ device number of the card in the master slot, I can do the appropriate clock routing. One reason makes this correlation necessary is that the device numbers that MAX assigns do not necessarily remain the same. Do you know of a way that I can determine a card's device number if I know the PCI bus and PCI device number? I am really trying to make a specific physical PCI slot be analogous to a PXI Slot 2.
Thanks for your help,
Mark
