Driver Development Kit (DDK)
sample infinite points about pxi6280 under rtx,please help me
I found another question when using pxi 6280. the exampels what you give about M series is sample finite point,but i want to sample infinite points. now I do not kown what register to control how much point I want to sample because of no pdf about the register information of pxi6280. I want to kown what regiser to keep sample infinite points. thanks!I really need help.
beilei
Message 1 of 12
(9,762 Views)
I don't know if it is possible.
I am trying to seek the answer.
Message 2 of 12
(9,753 Views)
I use aiex2.cpp about M series .I really want to konw how to config parameters of NI DDK aiex2.cpp to accomplish continuous mode,I really hope someone can help me.I look forward yor reply .thanks you very much.
beilei
Message 3 of 12
(9,750 Views)
as I understand the manuals a continuous acquisition is a post triggered acquisition waiting for a trigger that is never issued. One has to the  collect pretrigger samples at infinitum.
Try to change in aiex2.cpp from
   aiNumberOfSamples (board,
                       numberOfSamples, // posttrigger samples
                       0,               // pretrigger samples
                       kFalse);     // continuous?
to
                       0, // posttrigger samples
numberOfSamples,               // pretrigger samples
                       kTrue);     // continuous?
make the while loop reading the FIFO never ending.
I hope that this helps.
Message 4 of 12
(9,744 Views)
i change it like what you said,but it can not acquire the right data ,i really what i can do to solve this problem ,what regiser to control the infinite sample。please help me.i am very anxious. thanks a lot. if i can not solve the problem,i can not to do the next thing in project .
beilei
Message 5 of 12
(9,742 Views)
It's hard to do any guess without details. Could you sent necessary codes as attachement so that we can understand better?
Message 6 of 12
(9,731 Views)
I download your pages http://digital.ni.com/express.nsf/bycode/exyv4w?opendocument&lang=en&node=seminar_USabout M series of example aiex2.cpp under rtx ,it is to sampe finite points,I want to use it to sample infinite points,my question is how to change registers to sample infinite points. this example your company gave,why do you say i do not give your detail ?the examle is what your company gave. your company do not gave the regiser level pdf, so I want to kown how to change some registers to reach infinite samples in aiex2.cpp or use which example to change which register to reach infinite samples?
beilei
Message 7 of 12
(9,728 Views)
this is the example what your company give.I hope you can give me right anwer!
beilei
Message 8 of 12
(9,725 Views)
you have to set the number of pretrigger samples correctly in your example as I wrote in my last post:
/*>>>>> your code is wrong here:
/* This is correct:*/
                       0         // posttrigger samples
                       continuous);     // continuous?
Message 9 of 12
(9,702 Views)
I have tried  it like you asked before.Although it can sample infinite points,but the pionts are wrong when i test these points in maltlab. I hope you can think teal reason to tell me. who can really help me.i have waited for many days! thanks!
beilei
Message 10 of 12
(9,699 Views)
