Driver Development Kit (DDK)
osiTypes.h : #Target endianness not specified
Hello everyone,
Do you have any other solution to make the compiler recognize the kLitlleEndian=1?
I added this line in the compiler tab in the project settings but I still have the error saying the target endianness is not specified.
Thank you for your help.
Message 11 of 17
(6,001 Views)
I defined the kLitlleEndian =1 in the osiTypes.h file at the negining of the code (#define kLitlleEndian      1) and it works, I don't know if it's a bad thing to do but at least it compiles. Now I'm getting other errors about the target. I think the files for QNX dowsn't exist.
Here are the errors :
make -k EXTRA_SUFFIXES=cpp all --file=U:/PFE/monprojet/QMakefile36739.tmp
QCC osiBus.o tSTC.o tESeries.o
QCC -EL -g projet.o osiBus.o tSTC.o tESeries.o -o projet.exe
cc: unknown target 'gcc_ntox86le+debug'
cc: targets available in C:/QNX630/host/win32/x86/etc/qcc:
2.95.3,gcc_ntoarmbe
2.95.3,gcc_ntoarmbe_acpp-ne
2.95.3,gcc_ntoarmbe_cpp-ne
2.95.3,gcc_ntoarmbe_ecpp-ne
2.95.3,gcc_ntoarmle
2.95.3,gcc_ntoarmle_acpp-ne
2.95.3,gcc_ntoarmle_cpp-ne
2.95.3,gcc_ntoarmle_ecpp-ne
2.95.3,gcc_ntomipsbe
2.95.3,gcc_ntomipsbe_acpp-ne
2.95.3,gcc_ntomipsbe_cpp-ne
2.95.3,gcc_ntomipsbe_ecpp-ne
2.95.3,gcc_ntomipsle
2.95.3,gcc_ntomipsle_acpp-ne
2.95.3,gcc_ntomipsle_cpp-ne
2.95.3,gcc_ntomipsle_ecpp-ne
2.95.3,gcc_ntoppcbe
2.95.3,gcc_ntoppcbe_acpp-ne
2.95.3,gcc_ntoppcbe_cpp-ne
2.95.3,gcc_ntoppcbe_ecpp-ne
2.95.3,gcc_ntoshle
2.95.3,gcc_ntoshle_acpp-ne
2.95.3,gcc_ntoshle_cpp-ne
2.95.3,gcc_ntoshle_ecpp-ne
2.95.3,gcc_ntox86 (default)
2.95.3,gcc_ntox86_acpp-ne
2.95.3,gcc_ntox86_cpp-ne
2.95.3,gcc_ntox86_ecpp-ne
2.95.3,gcc_ntox86_gpp
3.3.5,gcc_ntoarmbe
3.3.5,gcc_ntoarmbe_acpp-ne
3.3.5,gcc_ntoarmbe_cpp-ne
3.3.5,gcc_ntoarmbe_ecpp-ne
3.3.5,gcc_ntoarmbe_gpp
3.3.5,gcc_ntoarmle
3.3.5,gcc_ntoarmle_acpp-ne
3.3.5,gcc_ntoarmle_cpp-ne
3.3.5,gcc_ntoarmle_ecpp-ne
3.3.5,gcc_ntoarmle_gpp
3.3.5,gcc_ntomipsbe
3.3.5,gcc_ntomipsbe_acpp-ne
3.3.5,gcc_ntomipsbe_cpp-ne
3.3.5,gcc_ntomipsbe_ecpp-ne
3.3.5,gcc_ntomipsbe_gpp
3.3.5,gcc_ntomipsle
3.3.5,gcc_ntomipsle_acpp-ne
3.3.5,gcc_ntomipsle_cpp-ne
3.3.5,gcc_ntomipsle_ecpp-ne
3.3.5,gcc_ntomipsle_gpp
3.3.5,gcc_ntoppcbe
3.3.5,gcc_ntoppcbe_acpp-ne
3.3.5,gcc_ntoppcbe_cpp-ne
3.3.5,gcc_ntoppcbe_ecpp-ne
3.3.5,gcc_ntoppcbe_gpp
3.3.5,gcc_ntoshle
3.3.5,gcc_ntoshle_acpp-ne
3.3.5,gcc_ntoshle_cpp-ne
3.3.5,gcc_ntoshle_ecpp-ne
3.3.5,gcc_ntoshle_gpp
3.3.5,gcc_ntox86
3.3.5,gcc_ntox86_acpp-ne
3.3.5,gcc_ntox86_cpp-ne
3.3.5,gcc_ntox86_ecpp-ne
3.3.5,gcc_ntox86_gpp
make: *** [projet.exe] Error 1
make: Target `all' not remade because of errors.
Thank you for your support.
Message 12 of 17
(5,998 Views)
The solution for the last error is to change the version of the compiler. First I was using the 2.95.3 gnu compiler version, I changed this in the default file to 3.5.3 and now it works and I don't have the errors I posted in the last message.
Now I'm getting others like these one :
make -k EXTRA_SUFFIXES=cpp all --file=U:/PFE/monprojet/QMakefile36750.tmp
osiBus.o: In function `tDMAMemory::~tDMAMemory(void)':
osiBus.o(.text+0xbc): undefined reference to `__builtin_delete'
osiBus.o: In function `tDMAMemory type_info function':
osiBus.o(.gnu.linkonce.t.__tf10tDMAMemory+0x1d): undefined reference to `__rtti_user'
tSTC.o: In function `tSTC::~tSTC(void)':
tSTC.o(.text+0x1583): undefined reference to `__builtin_delete'
tSTC.o: In function `tSTC type_info function':
tSTC.o(.gnu.linkonce.t.__tf4tSTC+0x1d): undefined reference to `__rtti_user'
tESeries.o: In function `tESeries::~tESeries(void)':
tESeries.o(.text+0x304): undefined reference to `__builtin_delete'
tESeries.o: In function `tESeries type_info function':
tESeries.o(.gnu.linkonce.t.__tf8tESeries+0x1d): undefined reference to `__rtti_user'
cc: C:/QNX630/host/win32/x86/usr/bin/i386-pc-nto-qnx6.3.0-ld caught signal 1
make: *** [projet.o] Error 1
If you know the source of these errors please help me.
thank you.
Message 13 of 17
(5,997 Views)
It's me again.
I'm sorry about all the messages I was sending, it's just because I still have 3weeks to finish my application and I still at the start.
I resolved all the problems I posted in the three last messages.
About the last one, I didn't specify the target in compiler command to generate the executable, now the command looks like this :
CXX := QCC -Vgcc_ntox86
Now I have the executable I needed.
Now Tom you told at begining of our chat that I need to execute the isDaq utility to make sure that my device is recognized. I exucuted the utility but I got this follwing error coming from sys/platform.h file :
    #error not configured for CPU
 I used VC++ 6.0 to excute isDaq.
There is any thing I have to change to be able to execute it.
Thank you.
Message 14 of 17
(5,997 Views)
Hi hamza-
It sounds like your executable was compiled for the wrong platform.  Did you run lsdaq on your development or target system?  Is the architecture of the target x86?  Perhaps this is a better question- are you able to build and execute a simple "Hello World" application successfully on your target?  This would help us rule out problems with the MHDDK itself.
EDIT:  One more thought- can you try to use the makefile shipped with the MHDDK to see if you're able to achieve better results?  Is there a reason that you prefer not to use it?
Message Edited by Tom W [DE] on 07-25-2007 02:04 PM
Tom W
Message 15 of 17
(5,988 Views)
Hi Tom,
First, I was not talking about the executable of my application , I was talking about the compilation of the isDaq utility, which gives me the errors I posted in my last message. I opened the project shipped with MHDDK but it gave me the errors.
I ran isDaq on my developpement system not on the target one. Both architectures are x86 platforms (developpement and target systems).
About the executable of my application, when I ran it the QNX developpement environnement pops a message telling that :
projet [C/C++ QNX QConn (IP)] projet.exe on qnxrtos1 (qnxrtos1) pid 540711.
qnxrtos1 is the name of the target machine. I checked to be sure that the executable is running on target machine and it was really there, so I don't think there was a problem during the compilation so it was compiled for the right platform.
Now to execute the isDaq utility in VC++ 6.0 I need to know if I should modify something or to define other things because it gave me errors saying that the compiler is not supported.
About the makefile sipped with MHDDK I used it at the beginning but it's too complicated for me to be able to modify it. So I decided to create my own makefile and now it works. I joined the most recent makefile the one I used to generate the executable.
Thank you Tom.
Message 16 of 17
(5,982 Views)
Hi hamza,
    I believe you must be finished with your project by now, but I have my own research project and am just now beginning to develop a driver for my ESeries card for QNX (with the Eclipse IDE in WinXP).  As a formal list, here are all the files that I include with my project in order to get everything to build:
  • tSTC.h and tSTC.cpp (in order to create tSTC.o)
  • tESeries.h and tESeries.cpp (for tESeries.o)
  • osiTypes.h
  • osiBus.h and osiBus.cpp (for osiBus.o)
  • osiUserCode.cpp (for osiUserCode.o)
  • the entire nimdbg folder and all of its contents
With these files included at the top of my project folder in the QNX IDE, I can build all of my necessary NI MHDDK objects and use them with my source code (such as the included examples).
    I am interested: what does your project involve?  I am currently trying to develop a continuous acquisition program on six analog input channels at a fixed rate, and I want to use an ISR to run my programs at very defined intervals while I read values from my DAQ card.
Message 17 of 17
(5,865 Views)
