Driver Development Kit (DDK)
Using DMA for 6133 board only returns zeros
I have code (attached) derived from examples and past undocumented R&D for getting analog input data from the 6133 DAQ board via either register based I/O, or DMA. The register based I/O works. However, the DMA provides all zero samples. I would appreciate it if someone with more experience with the MHDDK can have a look at it.
Thanks.
Definitions used from outside the file provided are:
#define DAQ_SAMPLE_RATE 2000000
#define NUM_ADC_CHANNELS 2
#define ADC_RESOLUTION 14
#define END_OF_CONVERT_DELAY 17
#define SAMPLES_PER_REV 4000
#define NUM_CHANNELS 2
(7,592 Views)
Maybe there is an issue with the iBus::allocDMA function for QNX Neutrino?
(7,471 Views)
Accepted by topic author Sorterralee
The problem has been fixed by using the 64 bit versions of memory related functions mmap and mem_offset in osiUserCode for Neutrino 6.
(7,452 Views)
ie. The fix is done in the function below, found in nimhddk/QNXNeutrino6/osiUserCode.cpp. Refer to lines in "#if NI6133_DMA_USE_MEM64"
tDMAMemory * iBus::allocDMA (u32 size)
    void *virtualAddress;
    off64_t physicalAddress;
#else
    off_t physicalAddress;
#endif
    // Allocate DMA buffer
    virtualAddress = mmap64( 0, // set target 0 means that the system can put it anywhere it wants
#else
    virtualAddress = mmap( 0, // set target 0 means that the system can put it anywhere it wants
#endif
    size,
    PROT_READ|PROT_WRITE|PROT_NOCACHE, // Can read, write. Should not be cached.
    MAP_PHYS|MAP_ANON, // Dealing with physical memory. With MAP_ANON means physical contiguous memory is allocated (required for DMA buffer).
    NOFD, // fd
    0 ); // offset within shared memory. "Common to map in an entire shared object, in which case offset will be zero"
    if (virtualAddress == MAP_FAILED)
        munmap (virtualAddress, size);
        return NULL;
    // Get physical adddress
    if (mem_offset64( virtualAddress, NOFD, size, &physicalAddress, 0) == -1)
#else
    if (mem_offset( virtualAddress, NOFD, size, &physicalAddress, 0) == -1)
#endif
        return NULL;
    tDMAMemory *dma = new tDMAMemory (virtualAddress, physicalAddress, size);
    if (NULL == dma)
    return dma;
(7,432 Views)
