10-29-2009 02:21 PM
Hello ,
I am using a ni PXI-6509 card for my application. Since I have to compile my application in Interval Zero RTX, I am using the static DIO Register level programming using VISA. I have successfully configured the card to do output on port0. But when I attempt to comfigure another port1(not the same as output) I can successflly configure it. But when I send 5V through the corresponding pins I donot get a value 1 in the Data register for that channel.
the following i did to configure as Input...
1) IO Select register set to 0 (for input as the manual suggests)
2) read from IO data register.
Do I need to do anything special to configure as input port.
please suggest...
Kuchi
10-30-2009 01:44 PM
Hi Kuchi,
So,one thing that I'm curious about is- are you actually using the Driver Development Kit? As well, have you tried using IO Select register to 1? Where in the manual did you see that you should select register set to 0 (I think I'm just missing it)? And, just to clarify- can you successfully output on all ports, or just port 0? Thanks!
11-11-2009 07:03 PM
Hi
We use VISA based Register level programming for E Series DIO channels for one specific purpose. We access only the following DAQ-STC Registers
DIO_Control_Register
DIO_Output_Register
DIO_Parallel_Input_Register
Window_Address_Register
Window_Data_Read_Register
Window_Data_Write_Register
The E Series RLP manual provides their address and offset correctly. We want to use the M Series Board and I am unable to find the DAQ-STCII RLP details. I tried the entire NI Site. Please provide the STC II registermap or atleast the register information of the above registers.
thanks and regards
Sathish
11-12-2009 10:44 AM
Joe Friedchicken
NI Configuration Based Software Get with your fellow OS users
[ Linux ] [ macOS ]Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
