Greetings!
I have an old legacy application (windows) using RLP on the NI 6533 (DIO-PCI-32HS). I am now told that this card will become obsolete and was recommeded to move to the PCIe-6535. I am trying to understand how compatible this card would be for our application, however I cannot find supporting documentation for this card in the MHDDK.
Can you tell me if/how similar are the registers between the cards, if there is available RLP documentation, if RLP is even support/recommended for this card, or what would be the preferred method for controlling the 6535? Our application only uses programmed i/o (read and write) but when we tried using visa before, it was much too slow.
Eugene.
