Driver Development Kit (DDK)
MHDDK function refernce for Ardence RTX
Hi,I'm using NI-6014 card with ardence RTX. I'm unable to find the complete documentaion for NI's MHDDK functions . I want to achieve the  maximum sampling rate with the card for 16 channels. Please help me in this
(7,909 Views)
Hi Vamit ,
    M Series boards are now supported by the Measurement Hardware Driver Development Kit (MHDDK). However, complete register documentation that explains how all of the registers work and how to perform advanced functionality is not available. A great substitute for this document is NI-DAQmx Base. You can use the NI-DAQmx Base VIs to see how to set the STC II registers to get the desired functionality and program it with the MHDDK.
- Why you  need RLP?
- how many boards you need to program with this ?
- Why won't DAQmx or DAQmx Base work for them?
Its also good for you to discuss the same with field engineers of your region for the register level programming .
Please let me know if this helps .
Pranchal
(7,893 Views)
I also see that u mentioned 6014 so an E Series Card! The same info applies to the E Series card also .
Pranchal
(7,892 Views)
