I am trying to make an multi device dma analog input aquistion on 3 M-Series PCI6259 cards on Windows7 using NI-VISA.
The dma mode is RING buffer on all 3 cards.
The first card is working, if i sequentially read the 2nd and the 3rd one after the 1st one
i get dma-read(..) status either kBufferOverflow or a timeout after x tries for the 2nd and the 3rd card.
If I disable the 1st card the 2nd card is working and the 3rd not.
Only if i stop via dma->stop (); and restart via dma->start(); after each aqusition I am able to recieve data from all 3 cards.
The solution with start and stop is not an option for me because it takes a lot of time and i have to read the always 1 sample from all 3 cards
after another for a real time controll.
I tried to use a different dma channel for the 3 cards but it did not help.
If anyone has an idea, i would appreciate.
regards
dsdtesting
