02-10-2010 11:18 AM
I want to sync several counters using on-board resourses (no external trigger). Is using the HW_ARM_SEL the best way to do that?
There was a post that explained how to use an external trigger source with the HW_ARM_SEL bits that
yielded an Accepted Solution. Can you drive the HW_ARM_SEL with an internal signal? Can this be used across the two TIOs?
Mark Horton
02-14-2010 12:20 PM
Joe Friedchicken
NI Configuration Based Software Get with your fellow OS users
[ Linux ] [ macOS ]Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
