Reply
Re: Why do I Receive Timeout Error -1073807339 on VISA Read or Write?
I am new user or labview,I am designing powersuppy for 4 channel and I successfully install all the driver and now i got the problem when I am tring to run this project stat that
Error -1073807339 occurred. Timeout expired before operation completed. What causes this error, and how do I fix it?
I am communicate my device by using RS232 cable.
and also here I am sending you attachment regarding to error page .
Pease reply me ..
thanks in advance..
(7,369 Views)
Hi akki123,
This error is returned because the device that is expected at the other side of the serial cable does not respond appropriately. There are a number of reasons for this; the most commons IMHO are:
* inappropriate serial settings: Check if you configured the driver to what the device is expecting (usually 8N1 with 9600 Baud (8 Data bits, No parity, 1 Stop bit). Check the device's manual!
* inappropriate serial cable: Check the device's manual!
* wrong port chosen:
It might be helpfull to use MAX to test the VISA serial connection first; you got more possibilities to asure a working connection with the device.
HTH!
Greetings from Germany!
LuI
(3,949 Views)
Highlighted
Thank you very much Lul,
I have checked all the setting and read the manual as you said,but still I am facing same problem .
I tried to check my initialization block diagram but in the Instrument Query Id I got the error here I am sending you that diagram and also my Ni max setting figure.
and One more thing that I am not able to open my visa test panel.
thank you again for reply.
(3,950 Views)
(3,950 Views)
Hello ,
any how I got success to run my visa control panel but still I am facing same problem during when i tried to run my initialize.vi in read visa.
I am really need your help as i stuck here in this problem from last 3 days.
will you please guide me here i am sending you my labview example with some error snaps.
Thnaks in advance.
(3,950 Views)
Akki123,
I am a user like you and I have my own tasks, so I can't look here at any time ;-)
You know, your code returns an error when reading the first time from your instrument. As you never got any response it is hard to tell what causes your problem. Still the same possibel reasons as I stated above.
What I'd suggest is to return to VISA control panel, configure your port and send a message to your device; best the proper 'IDN?' command (again, look in the manual, every manufacturer may have its own command set). Afterwards you try to read about 25 Bytes from the device and check if it is what you expect. If you get anything you know that you etsbalished the communication, but the command was wrong. If you get nothing you know your command was either incomplete (Missing 'CR' (=0x0D) or 'CRLF' (==x0D0A) ?, RTFM), bad at all and the device does not react on incomplete or bad commands, or your port configuration was wrong.
Another point to check is the actual setting of your device - someone might have changed it sometimes in the past. RTFM and try to check the actual comm params with the help of the devices menus. The power supplies and DMMs I know allow tom change baud rate between 4800 to 9200 Baud, for example...
(3,950 Views)
Reply
