Dr. LabVIEW
Reply
Highlighted
Quickly Navigating Structures on the Block Diagram
Introduction
Navigating through structures on the LabVIEW block diagram can cary in complexity from extremely easy (a True/False case structure) to extremely time consuming and frustraing (an event structure in a stacked sequence structure in a case structure). And since there are three ways to navigate through structures, you can decide which time is best to use each different way. I only talk about the lesser known way in my blog, so check it out!
1) Slow sequential navigation. You can use the Left/Right arrows on either side of the selector lable to navigate slowly through the structure one by one.
2) Non-sequential navigation. You can click the down arrow, and choose which pane of the structure you would like to see.
3) Finally, you can use the way I discussed in my blog, and just hold your control key while scrolling your mousewheel, and you'll fly through the structures.
Enjoy!
Message 1 of 1
(5,129 Views)
Reply
