Dr. LabVIEW
Reply
Highlighted
Creating VI Snippets in LabVIEW 2009
VI Snippets
Have you ever been frustrated with someone sending you a screenshot of their code instead of the actual VI? Well, with VI Snippets, the screenshot IS the code. A VI snippet will create a PNG that is embedded with some meta-data that is unique to the VI. This meta-data will actual store the information from the block diagram. Once you have this PNG, you can drag it to any block diagram you want to instantly replicate the code that the snippet was created from.
Steps to Complete
Highlight some code on your block diagram. Then go to Edit»Create VI Snippet from Selection. This will prompt you to save your PNG, so go ahead and save it. Now you can drag this PNG to any block diagram, and the code will instantly pop off for you!
You can also watch the Youtube video posted on my blog to see how a snippet can be used, or try it yourself with the attached snippet below!
Additional Notes
If you open and edit the snippet in any image editor, you will lose the meta-data crucial to keeping the code.
(10,107 Views)
Re: Creating VI Snippets in LabVIEW 2009
Nice post, it would have been nice to use an actual snippet instead of an image of a snippet. I was showing someone how great they were and I couldn't drag the image in this post to my code
If someone else is trying to do the same, you can find some snippet examples here: http://zone.ni.com/devzone/cda/tut/p/id/9330
Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
(1,805 Views)
Second  that,  I  tried  that  and  it didn´t  work .  Edit -  Create VI Snippet from Selection. Thanks for the link FabiolaDelaCueva
(1,805 Views)
Thanks for the tip!
(1,805 Views)
Very usefull!!
(1,805 Views)
Reply
