Do More with Your NI USB-TC01
Reply
Highlighted
NI USB-TC01 LabVIEW Example - Virtual Panel Meter
This Virtual Panel Meter was created using LabVIEW 2009 and emulates a physical digital panel meter.
The Virtual Panel Meter was programmed using the NI-DAQmx API. In each iteration of the loop, a thermocouple measurement task is created based off of the current configuration and one sample is read. The sample is sent to a sub VI (Number to Array of Digitals.vi).
Chris Delvizis
(13,979 Views)
Re: NI USB-TC01 LabVIEW Example - Virtual Panel Meter
Very good VI but can you tell me where you found the photos used as digitals (0,1,2,3 ....) or how do you created them. Thx
(1,804 Views)
Hey nizartun,
I actually created the images for the digital numbers myself in powerpoint. I attached the ppt file and the font I used above in "UI source for Panel Meter.zip". You also may want to check out the UI Interest Group community which has some tips for creating great looking LabVIEW UI's.
Chris Delvizis
(1,804 Views)
Thank you so much  Chris_D.
(1,804 Views)
Nice Panel Meter, how would I go about resizing it?
(1,804 Views)
Reply
