Do More with Your NI USB-TC01
Reply
Re: NI USB-TC01 1.0.1 Firmware Update Now Available
For anyone else who finds this posting, and has had problems after attempting the firmware update, I found a fix that may work for you.
After having a conversation with AE Shawn Shaw, he sent me an email asking me about my OS version, and whether I found file 'NIUSB74B7.bin' under c:\windows\system32\drivers.  It wasn't there, but there WAS a copy one level up (\windows\system32), so I copied the file down into the \drivers subdir.  Reconnected the TC-01 and it was properly identified and fully functional.  I'm just guessing, but it may be a problem in the updater specifying the wrong target directory for installing the file.
'CoffeeRoaster' , I hope you get an email alert when someone posts a followup here.
Dave
David Boyd
Sr. Test Engineer
Philips Respironics
Certified LabVIEW Developer
Message 11 of 18
(183 Views)
Thank you for posting David.  We have identified an installer issue that affects proper installation of this utility on 64-bit operating systems.  I removed he current installer from the web for now, but I will post back when the issue is corrected and the installer is live again.
Best Regards,
Brooks
Product Suppot Engineer:  Conditioned Measurements
Brooks
Message 12 of 18
(183 Views)
Hi Brooks,
The link : Download the NI InstantDAQ Firmware Update Utility 1.0.1 does not work.
Have you solved the problem ? If yes where can we get the updated firmware ?
Alain
Message 13 of 18
(183 Views)
Is this a dead issue or is someone working on the updated firmware?
Message 14 of 18
(183 Views)
No, we are working on it.  We're just finishing up some testing and we'll repost it when we are done.
Kristen
Message 15 of 18
(183 Views)
Hello Everyone,
We have finished testing the fix and the download is now available at the same link as before.
Thank you for your patience.
Brooks
Message 16 of 18
(183 Views)
same link---doesn't work
Message 17 of 18
(183 Views)
New firmware update (v 1.1.0.f1) available through this link:
http://www.ni.com/download/ni-instantdaq-firmware-update-utility-1.2/5284/en/
Sebastian
Message 18 of 18
(183 Views)
Reply
