In LabVIEW, we can easily create a VI that is comprised of a bunch of subVIs and reuse that VI.
How do I go about creating a DCAF module that is composed of groups of (sub) modules? I want to be able to create a higher level module that has multiple sub-modules so that I can replicate (make multiple instances of) the higher level module easily.
For instance, if I desire to create a module named TempSystem comprised of the following two DCAF Example modules:
1. Temperature Controller Logic module
2. Temperature Chamber Model
And I want to be able to be able to create, let's say, (5) TempSystem instances without having to individually create (5) Temperature Controller Logic modules and (5) Temperature Chamber Models and map them all together.
Furthermore, if I have different brands of Temperature Chambers (and therefore different modules for each Temperature Chamber, but having the same channels), I would like to be easily reconfigure the system to use the new module without having to remap all of the connections.
Is there a way to do this, or is there a different way to go about achieving similar functionality?
