annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
counter for Led
I am a beginner in labview and I  want measure the time the LED spend on and off.
thank you
0 Compliments
Message 1 sur 4
2 226 Visites
Hello rabab,
Can you provide us more context?
What LED are you talking about?
Is it a boolean indicator? Is its value set from a measurement or a calculus?
Don't hesitate to join your code.
Have a nice day.
Kind regards,
Armando
0 Compliments
Message 2 sur 4
2 207 Visites
hello,
thank you for replying,
the led is of type boolean. I want to make a connection between step7 and labview,  when I activate the PLC entry the led turn On  and when I disable the LED turn off.
I want to measure how much time the LED stays on.
sorry for my bad English.
0 Compliments
Message 3 sur 4
2 203 Visites
Hello rabab,
I would suggest you to use an event structure for doing it (http://zone.ni.com/reference/en-XX/help/371361P-01/glang/event_structure/).
You can start a timer (VI Counter) when the boolean is changing its value and then stop it once again at second value change.
Good luck!
Kind regards,
Armando
0 Compliments
Message 4 sur 4
2 161 Visites
