le 08-10-2005 03:57 AM
le 08-17-2005 12:34 PM
le 08-18-2005 01:39 PM
Thanks for this information.
I think I can solve my problem.
In fact, I would like tu acquire both channels during the displacement of my stepper axis connected to PXI-7344 board and Motion accessory UMI-7764.
So I need to SYNCHRONIZE the motion board 7344 (position/displacement capturing) and the DAQ device (4204) by using RTSI method with RTSI-Lines integrated in the PXI-Chassis (1031).
I know I have to use DAQmx VIs since 4204 doesn't support traditional DAQ.
So the problem would concern then the data storage
Because I 've been using until now the DAQ Assistant (express VI palette) and the Wrtie LabView Measurement FIle which save under *.lvm format. Then I had to load in ASCII format in DIadem since the version 8.0 doesn't support TDM format...!:smileysad
Although I've tried many times and many times, I can never load the LabVIEW/Diadem Connectivity VIs from NI Web Site...?!
And is it possible to update LabView 8.0 to 9 to use the Storage VIs so that I can store files directly in native Diadem file formats?
THANKS A LOT FOR YOUR PRECIOUS HELP
B. Tafati
I found some VIs interesting
by using some One more thing, I can never load the LabVIEW/Diadem Connectivity VIs from NI Web Site...?!
And is it possible to update LabView 8.0 to 9 to use the Storage VIs?
Regards
B. Tafati
08-24-2005 04:34 AM - modifié 08-24-2005 04:34 AM
Concerning your MOTION questions, I advice you to post your question on the motion control forum (http://forums.ni.com/ni/board?board.id=240). You will find some experienced developers and motion control specialist in this forum and you will get more easily an answer to your questions.
I do not understand why you speak about LabVIEW 8.0. LabVIEW 8.0 is not released. Which version of LabVIEW are you using, which version of DIAdem? Could you explain with more details what is the problem with saving/loading you data in ASCII format? Why you cannot download the DIAdem Connectivity VIs?
Thanks for the details.
Matthieu G.
Message Edité par Kerouac le 08-24-2005 11:50 AM
Message Edité par Kerouac le 08-24-2005 11:51 AM
