le 07-22-2009 04:38 AM
I'm using Lv FPGA 8.6.1 to call a VHDL code inside a cRIO 9103.
To do this, I'm using a CLIP node. Everything is fine with this. The VHDL code is doing exactly what I want on the target.
I just want to add some timing constrains to the output "out_port"' of the CLIP node. (See the UCF in the zip attachment).
When I try to compile the VI "Bug.vi", I get the following error:
ERROR:NgdBuild:756 - "toplevel_gen.ucf" Line 2: Could not find net(s)
'*window/theCLIPs/MyCLIP_CLIP0/out_port*' in the design. To suppress this
error specify the correct net name or remove the constraint.
ERROR:Parsers:11 - Encountered unrecognized constraint while parsing.
ERROR:NgdBuild:19 - Errors found while parsing constraint file
"toplevel_gen.ucf". "
As the XML file is declared correctly, and the entity as an output called exactly "out_port", I don't understand why I have this error. It seems that the net path is not correct.
I think that my UCF file is correct. Is there a tricky thing I missed ? As I've tried everything, I do not have any idea.
Thanks for your help.
le 07-22-2009 10:16 AM
It is common for the Xilinx tools to rename a net during the compilation process. This causes the port called "output_port" to no longer exist when the tools attempt to apply this constraint. I believe you can add a 'keep' directive in your HDL code to preserve a net name and allow your constraint to work. Review the Xilinx constraint guide for details.
However - what aspects of your CLIP interface require timing constraints? Can you access the I/O synchronously and therefore depend on the clock period constraint to verify timing instead of the net constraint?
-RB
