annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
using halcon
Résolu !
Accéder à la solution
LabVIEW calls the Halcom operator, the operator needs to enter an int integer, but in the Halcon is using the Htuple data type, how can I in LabVIEW to convert the int data to the required data transfer to the Halcon operator??sigma.png
0 Compliments
Message 1 sur 5
3 240 Visites
HELLO,
If I well understand, you want to transfer data from LabVIEW to "HImage" which use the type "HTuple sigma" and you can't because in LabVIEW it doesn't exist, i'm right ?
See with the function "Adapt to Type" in LabVIEW if you can match the data to "HImage".
Kardio
0 Compliments
Message 2 sur 5
3 185 Visites
Accepté par l'auteur du sujet mooner
Create new HTuple object with .NET Constructor Node. Do not forget to free the object in the end with Close Reference.
0 Compliments
Message 3 sur 5
3 132 Visites
Thankyou very much!Your anwser perfect solution my question..
0 Compliments
Message 4 sur 5
3 079 Visites
You are right.AS you can see,i neet to use more time to learn English.Chat gêné
0 Compliments
Message 5 sur 5
3 077 Visites
