annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
centrifugal compressors simulation
I'm performing my graduation project with a company in Tunisia and I have a problem. The main idea of the project is to make a simulation of a centrifugal compressor using LabVIEW.
My first step is to make the  front panel as an interface which contain a centrifugal compressor as an indicator and some simple boolean controls
==> (it's a simulation of a real system without hardware).
My problem is how to put the centrifugal compressor from Solid Works to the LabVIW front panel as a picture then to use it dynamically
Example:
When I actuate a boolean button I should see it moving (in the front panel and not in the Solid Works) .
If it's possible, can I have an example or can you tell me how to proceed.
Thanks in advance & Best regards,
0 Compliments
Message 1 sur 2
4 152 Visites
You can put "LabVIEW and Solidworks" on Youtube and you will find many tutorials for your application.
The videos will help you more than a long speach.
Alexis
0 Compliments
Message 2 sur 2
4 135 Visites
