06-05-2018 02:04 PM - modifié 06-05-2018 02:16 PM
Hi / bonjour,
I'm a new LabView user, I'm an undergraduate student who just started to work in a lab for the summer. I have the mission to track the mice movement in cage during a minute or so. I am a physiology student and as you would have guessed, computer science or programming is not my first asset..
This is why I'm posting here today. I have been looking at a fair amount of VI examples, watched dozens of video and tried really hard to understand how LabView could help me realising my project. Unfortunately, I am stuck and stressed by time.
Because a video is worth a thousand words, this is what I would ideally achieve:
https://www.youtube.com/watch?v=WPnWDGl3XZc&t=0s&index=15&list=PLhy8Q3goV3J_Rr1SwMyJ4MO-aMIjTa2R4
I used the vision assistant to localise a coloured object in my environment and track its motion but I cannot go further.
If anyone could help me on this, I would greatly appreciate! I'm ready to put some work and listen to whatever you have to teach me.
I thank you in advance!
Pierre
PS: je parle couramment Français!
le 06-07-2018 07:13 AM
Hello Thepiero,
Can you post a portion of the code to know where the problem is?
Thank you,
Have a nice day
Corentin
le 06-11-2018 11:59 AM
Bonjour,
Désolé pour le retard, pas mal de boulot à l'université..
Voici 4 different screenshots représentant notre code. Nous pouvons detecter un morceau de plastique rouge que nous avons attaché a la tete de notre souris. Cela marche relativement bien!
En revanche, nous n'avons toujours pas réussi à obtenir la trace représentant le mouvement de la souris.
Merci d'avance pour l'aide!
Pierre
le 06-11-2018 12:33 PM
peux tu mettre un peu d’ordre dans ton code pour qu'il soit plus lisible ?
le 06-11-2018 01:00 PM
Bonjour,
Je ne connais pas le raccourci pour simplifier le code. Voici le VI, vous avez certainement plus l'habitude que moi!
Merci d'avance!
Pierre
le 06-11-2018 03:11 PM
Je n'ai pas Imaq mais tu peux t'inspirer de l'exemple Pen Attributes And Image subsetting.vi (mode Free Line Form). Il semble également y avoir un exemple du module Vision qui se nomme Path Following.lvproj qui semble intéressant dans le cas présent. Il faudra probablement que tu ajoutes un registre à décalage pour passer la position des points précédents au point actuel.
Ben64
le 06-12-2018 10:46 AM
Merci pour la réponse!
Je vais essayer d'en apprendre un peu plus aujourd'hui au lab et je reviendrais vers vous pour vous tenir au courant!
Pierre
