Hello José Alberto,
Using custom signals as an input to Multisim will give you better simulation results. There are two posibilities:
- Multisim can read LabVIEW Measurement files (LVMs) using the LVM_VOLTAGE component. However, the LVM file needs to be generated using LabVIEW. You can find more info about this approach here.
- Use the Piecewise Linear Source (PWL) component. In this case you need to create a text file with the values of the signal you want to generate. The data to be import must be voltage or current vs Time. In a text editor (e.g. Notepad), you can simply have two columns: time and voltage. The PWL source can be found in the Master Database, Sources Group, SIGNAL_VOLTAGE_SOURCES family. Place one on the workspace and open its Properties to see the format of the text file.
I'm attaching a zip file that contains an example. Give it a try and let us know how this works.
Fernando D.
