cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
events/without user intervention at the GUI
I am developing a control application in which in open loop the user has interaction with controls in the GUI and a generation of events begin an action. However in closed loop the controller generates the values and rewriten the values at the controls in the GUI without intervention of user in the GUI. The events are not identified within the events loop located within the white loop. I am trying to work with Dynamically Registering Events but i am not have sucess. The specific question is how generated an event when a value control changes  without the intervention of the user in the GUI
0 kudos
Mensaje 1 de 3
3.786 Vistas
Gracias por utilizar los foros
la solucion ya la tienes en esta liga
http://forums.ni.com/ni/board/message?board.id=170&message.id=196808#M196808
saludosGuiño
Erwin Franz
Certified LabVIEW Architect, Certified TestStand Developer
0 kudos
Mensaje 2 de 3
3.740 Vistas
Gracias. Ya tenía la solución en esa liga. De qualquier forma gracias por la atención.
Jaime
0 kudos
Mensaje 3 de 3
3.732 Vistas
