el 11-09-2020 02:51 AM
Buenas. Estoy leyendo unas columnas de un excel con muchas filas a través de un array. He dividido cada columna en subarrays para tratar cada columna por separado pero necesito convertir ese subarray en un número para que lo lea un equipo de un laboratorio. He probado a pasar el subarray a un string donde me ha leido todos los valores de mi subarray, y eso lo he convertido a número utilizando la función Frac/Exp String To Number, en el que solo me lee el primero de todos los valores que necesito leer. Dejo fotos de mi programa (foto 1) lo que sale del array (foto 2) lo que sale de convertir a string (foto 3) y lo que sale de convertir a número (foto 4). Agradecería ayuda.
diferentes tipos de saltos de línea pero no funciona.
¡Resuelto! Ir a solución.
el 11-09-2020 03:25 AM
Hi Goku,
you should write your questions in English when you post in the English section of the forum…
@GokuJubilao wrote:
I am reading some columns of an excel with many rows through an array. I have divided each column into subarrays to treat each column separately but I need to convert that subarray into a number for a team in a lab to read. I have tried to pass the subarray to a string where it has read all the values of my subarray, and that I have converted it to a number using the function Frac / Exp String To Number, in which it only reads me the first of all the values that I need to read. I leave photos of my program (photo 1) what comes out of the array (photo 2) what comes out of converting to string (photo 3) and what comes out of converting to number (photo 4).
You already get a numeric array from those RGT function on the left of your images: why do you need to convert that array into a string instead of using plain array functions?
Btw. we cannot debug images using LabVIEW, so it is recommended to attach real code instead of some images of parts of code!
el 11-09-2020 04:18 AM
Hello. This is my first project programming in labview and I am learning. I need to convert the array into a number in order to read the numbers and convert this numbers into string so the VISA functions can read it. I tried to convert array into number but it didn't work. I'll try to explain my problem. My power supply must read all the values of the colum in the array, but the VISA just read number so my solution was to convert array into string and it just read the first value when i convert string into number.
11-09-2020 05:01 AM - editado 11-09-2020 05:39 AM
el 11-09-2020 05:33 AM
It worked. I thought I had to convert array into string because i didn't find too much information abaut that but you could solve my problem. Thank you very much. Best regards.
