cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Operacion matematica
hola que tal buen dia tengo un problema ala hora de ejecutar una operacion matematica ya que cuando hago la resta de 10-8.5 el resultado aveces me lo da correcto pero aveces me arroja 1 u otro numero me pasa en algunos label tendrian alguna sugerencia que pueda ayudarme
0 kudos
Mensaje 1 de 5
5.572 Vistas
The diagram would be much more interesting to see. (My guess is race conditions due to local variable over-use).
0 kudos
Mensaje 2 de 5
5.564 Vistas
0 kudos
Mensaje 3 de 5
5.468 Vistas
Hard to troubleshoot. Way too much duplicate code and way too many value property nodes.
How do you operate it (step by step instructions!), what do you expect to see, and what happens instead?
0 kudos
Mensaje 4 de 5
5.443 Vistas
OK, you need to learn about dataflow. Having 45 instances of a value property node for a given terminal is excessive. You need exactly zero value proprty nodes (or local variables).
Use clusters of buttons for the two types of inputs.
Make the code scalable! Imagine you have 1000 different items. How would your INICIO event case look like :o! How many code changes would you need to do if the price on a single item changes? Unmanageable!
Here's a quick draft to give you some ideas how to implement the suggestions. Modify as needed.
0 kudos
Mensaje 5 de 5
5.422 Vistas
